Habiatable room to store room
29 Jan 2012
I've started a garage conversion, I had to get planning permission as its on a new estate and had no permitted development rights. Builder knocked doorway through and installed a window.
My original plan was to split it and have the front half with the garage door as a store and the back with the door into the house as a spare room. I'm doing the internals, I've got to admit I made a cock up and only informed building control after I started. By this point I had put up the partition with 50mm of insulation and put 25mm of celotex behind plasterboard on the dividing wall into the next garage (single skin of thermalite blocks).
Unfortunately the building inspector has told me I need to add at least another inch of insulation onto both walls, and the real killer, 75mm of floor insulation. This would be a real issue as the garage floor is actually slightly higher than the house, so would create a big step up. I would also need to change the door heights.
So leaving behind the fact that its my own fault for failing to inform building control early enough, can I change the use of the room to a store room, ie non-habitable, and therefore avoid having to rip everything down to fill it with insulation?
Hope that makes sense?
You can just sack your BCO, tell him its no longer a habitable space therefore no longer requires building regs approval. Apart from being cold of course the only other thing will be that you'll never lawfully be able to call it a habitable room.
But in the first instance I would be discussing with the officer what alternative measures he may accept, ie maybe just having say 25mm floor insulation but increased wall or roof insulation to compensate.
dig out the garage floor before you add insulation
Use more efficient (and probably expensive) insulation. You don't need "75mm" of insulation, you need to achieve a specific U-value.
