The Halstead Finest Gold combi boiler installed in my new house was fitted about 6 years ago and all the pipework for the CH and DHW had been finished but no radiators had been fitted. The small building firm doing the work went bust. I have now fitted 7 radiators and filled, flushed and re-filled the system . I have left the system at 2 bar and have followed the set-up procedure in the manual. The boiler when first switched on, with the time clock OFF and only the DHW control turned fully clockwise, goes through its checks and after 6 or so seconds stops the fan and pump and sits there with a green light on waiting for a hot water demand. When the hot water tap is opened and I run down stairs to check, the boiler is showing the red lockout light. I can`t tell if the boiler is trying to light or not. Is there a way to get the boiler to use the ignition sequence without having the gas turned on? Could the gas pipes be full of air even though all the valves are open. The gas hasn`t been turned on for about 6 years either.
Any ideas?
Thanks!!
Any ideas?
Thanks!!
