Heating but no hot water
2 Dec 2005
Yorkshire
I have gravity hot water & pumped heating system,but I am getting no hot water.The radiators get hot,but I still don't get hotwater.
Do you mean that the hot water is from a different tank (i.e. electric immersion) or does it heat from a combi boiler?
If it is a different system, check your fuses/trip switches, heating element (inside the tank), thermostat.
It would be useful if you have a little more info - i.e. is it an electric boiler for the hot water, is the tank split in 2, etc
Good luck.
Gary
Its probably an air lock! you need someone with experiance to remove it,
