O
oldgazza
Having had a new boiler fitted in the roof space last year the installer fitted a frost stat and pipe stat. All worked fine until the weather dropped below 5c when of course the frost stat came in and started working as it should.
What happened next was that for the next 3 months as the temperature remained below 5c was that I had no control over the temperature with in the living area at any time. The house temperature would reach up to 30c but would average at around 24c which is way to hot for me.
As our house has the maximum recommended insulation the heat obtained from the heating while waiting for the water to reach the pipe stat on the return pipe, completely overrides the central heating programmer. For several months.
This sounds very excessive to me not to have control over the heating other than radiator thermostats.
The new boiler is a baxi duo tec 33He with Honeywell pipe and frost stats. The old boiler was previously fitted in our integral garage which had no heating and had a similar stat setup without the over heating problem. We have again had the installer re check the system and every thing is working as it should other than we are unable to control the heat properly in the living space.
Has anyone had similar problems or have alternative thoughts on how to tame this out of control set up.
