Heating & hot water only warm until i only call individu
28 Jan 2009
Pembrokeshire
heat only boiler
6 radiators
cylinder
3 port valve
call for heating and hot water - water only warm and downstairs rads cold at the bottom
put hot water on its own - red hot
put heating on its own - red hot
Check the pump setting.
Also make sure the valve is moving to mid-position properly.
Are you Gas Safe reg?
If so then why dont you post in the CC ?
I would love to give you some advice but would want to know boiler model an to reply in the CC.
