Hi all
As per the title really. I need some advice if possible.
As most people seem to be turning on their heating around about now, we have recently done the same.
Turned the heating on and it's not working. It's not working independently without HW being on. It's only working when the hot water is active and filling up. If the hot water tank is full, the heating won't warm up. We have a 'normal' boiler, not combi. Sorry don't know what they're called!
I've looked in the airing cupboard and the valve appears to be working. I've had the wife turn each heating and hot water on in stages and the valve turns. I've held the pipe that feeds the radiators and when the heating is turned on with the hot water, you can feel the pipe suddenly go boiling hot, so to me, there's nothing wrong with the central heating itself. When the hot water is off, the heating is on, there's no hot water flow down this pipe. The boiler neither fires up when heating is switched on alone.
I'm at a loss! I'm no expert at all, just a little knowledge that I've read myself and what plumbers have said when we've had previous problems.
We have a Tower 3 port valve. This was replaced about two years ago by a plumber. The pump is also working, this is a DAB pump that's was also replaced about two years ago.
I thought there may just be an air lock so I've banged the pipes to no avail.
I would appreciate any advice! Hoping this will be a DIY job as opposed to calling someone out.
Many thanks in advance.
