Has anyone used wago connectors instead of the traditional wiring centre with the terminal block?
What's your experience been? Easier to wire and diagnose?
I used them when I did spotlights and it was very easy than fiddling around with screws. Cut wire to length with easy wire strippers and straight in. Give a little tug to check if secure.Interesting idea.
As you know with my current dilemma, I whacked in a pump and it's very hard to give the wire a tug particularly when there's more than one wire in a single terminal.
Ideal connectors are bit cheaper and see through so you can see the wire.I recently rejigged my wiring centre (DIY version ! ) to have a time delay on the boiler firing.
I ended up just unding all of it and starting from scratch as i couldn't remember the sequencing.
Wago's would have been very handy and a lot less faff.
The 221 connectors are difficult to stick in probes.Wago make a couple of different wiring centres
The L32 comes complete with the correct 221 connectors: https://www.toolstation.com/wago-mbox-wiring-centre/p31734
The L60 is supplied as a box without connectors and is suitable for series 221 4mm Connectors: https://www.tlc-direct.co.uk/Products/WAL60.html
You do need a small (2mm) probe for a 221 connector. If you don't have any then Wago sell them:The 221 connectors are difficult to stick in probes.
The ideal Connectors are better but they don't come in a similar wiring centre box. It would be a case of leaving them in a enclosure
