I`m a reg installer and was wondering what is the physical difference between the two? I know the plate heat exchanger is larger on the 35 but what else? Is the burner and or p.c.b different or can you alter the `ramp` for larger output?
mmm... I hope you not planing to try and "up rate" a 30kw boiler to a 35kw boiler. (they never made a 24kw solaris but did call a 30kw one a 24pc )
the 35kw has one extra coil set in the main heat exchanger. a different burner and gas restricter on the gas valve.
so no you cant ramp up to 35kw
agile is right about it being discontinued. you can still get your hands on a 30kw ones but the 35kw ones are sold out, I have a 35kw one sitting in my garage, one of the last. it will be sorely missed .
the new "Sargon" is what replacing it...the vizo plus is a Sargon
