- Joined
- 10 Dec 2023
- Messages
- 3
- Reaction score
- 0
- Country
I live in an apartment, I have the following items as part of what I feel is a complex system.
- Heatrae Sadia 900
- PrimaFlow CP5
- Two yellow boxes (pump valves, assuming on and off peak?)
- two switches one for off peak and one for boiler
- Albion Ultrasteel boiler
- Zilmet 10 bar 110-Ultra Pro (no idea what it is)
- Red tank, looks similar to Zilmet above but smaller and with a valve on it with bars, immersion heater?
That's the setup, in terms of thermostats I have one for the hot water which SHOULD turn on between 2am and 5am but doesn't and then an old online system called Owl Intuition which does the heating and of course all electric, no gas.
Now, for ages now, the PrimaFlow CP5 has been very loud, when its heating water or whatever it does, the other day the heating didn't turn on so I bled the CP5 and then the heating turned on... I am not sure if since then I triggered a switch or something, because nothing has worked after the heating turned off.
The valve on the red tank, looked low, so today I opened up the water valves to add pressure, thinking that would help, it didn't.
Now, I am pretty much at the point I don't know where else to go... I am going to be calling an engineer tomorrow, but since I don't know any engineers, thought I'd come and ask you fine experts first.
NOTE: The Heatrae Sadia system call light goes green and heat light goes orange/amber for a minute or so then stops when I try and manually get the hot water or heating turned on, so it seems for whatever reason the heatrae sadia 900 doesn't want to fire up.
- Heatrae Sadia 900
- PrimaFlow CP5
