Hello,
Please excuse my naivety, but I was wondering if somebody could shed some light on a boiler problem for me and give an opinion for the second issue as to whether it is normal or not?
1. The boiler (W-Bosch 19/24CBi) sometimes will refuse to re-light (if at all) for heating the DHW with no lock out light visible, yet I can hear a noise like a fan running when I come down in the morning. The demand is there, but it doesn't fire. When it does, it will only light (even from cold) for about 5 mins at the very most but more commonly 2 minutes before going off again for about 4 or 5 minutes each time. Could this be due to sludge or scale?
2. When the water has been heating correctly in the past, I could always hear the noise like water circulating in the pipes feeding the rads all around the house. Is this normal? Is it sound being carried around the system from the pump in the airing cupboard? I have never noticed it at my other previous properties.
Finally, just in case it is related, I have also noticed that with the hot water expansion tank in the loft that although it has about 4 inches of water in it, it does not fill when the float is pushed down (I have checked the feeding valve is open).
Any thoughts or opinions much appreciated.
Thanks,
Jpm777
Thanks,
Jpm777
