breezer said:If you have 2 reds then it will not matter much . The reason your cable has two reds is the electcian who installed it used the correct cable.
The regs changed, previously a cable with red and black (with red sleaving / tape over the black) could be used now you should use twin red, as the electrcian did
is there not a small terminal on the back of the switch itself (physically attached to the brass, nothing to do with the switch/) if so after you turn the mains off connect a 1mm wire between this and the metal back box that the switch fits into. there should also be another earth wire at this point which is the incoming earth.
The earth wire should be covered in green sleaving
1) Both - the cpc in the circuit cable should go to the earth terminal on the switch AND then you should run a flylead from there to the back box.Do i need to put an extra earth wire in from the back box or switch it from the back box to the metal switch?
cheers
