I have recently had a new combi boiler installed...
When it got fitted all the radiators worked fine but since then I think I may have turned some valves...
Now, i have been advised that all that needs doing is to re balance the system (as I was going to replumb all the radiators in 15mm plastic pipe).
All the radiators bar 1 are in microbore pipe, there are 3 upstairs in each bedroom and 3 downstairs, 1 small 1 in the hall, 1 large one in lounge and an add on (before i moved in) in the bathroom (which is downstairs) but this 1 in the bathroom is in 15mm copper.
So heres my problem, I turn the heating on and the radiator in the bathroom in 15mm gets really hot (water obviously taking the path of least resistance) but the others are stone cold, i have all the inlet valves on all radiators open fully but the out (locksheild i believe) valves 1 and half turn downstairs and half turn upstairs (as advised) but still no joy, the pipes are definitely hot going into all radiators but just doesn't run through the radiators..
(bit more info, the systems has been powerflushed a couple of months before the new boiler install)
Any help is greatly appreciated.
Kind regards
Ashley
Kind regards
Ashley
