Help re woodrot
11 Feb 2004
Essex
I have a hardwood conservatory which has suffered from wet-rot in minor areas: base of one of the windows wooden seal has partly wet-rotted and two of the wooden supports at the base. No real structural damage.
Advice needed as to how to repair and with what.
Thanks.
if its really bad then the bad sections need removing then new pieces scarfed in,if its small areas then you might be able to treat with a wood preserver then with a wood hardener then with 2 pack filler?
Thank you for your reply and advice.
Does that mean removing all areas of wet rot before following your advice?
think your have to decide that yourself,i:e how bad it really is?
