My house was built nearly 24 years ago and I would like to change one of the original radiators as part of a downstairs toilet refurbishment. It's the smallest radiator in the house measuring 49cm wide and 42cm high. The pipe centres are at 57.5cm and around 3.5/4cm from the wall. The size of the radiator is the problem as I can't seem to find any radiator that is a similar size.
View media item 107615
View media item 107616
I wonder if based on your experience you might be able to point me in the direction of a radiator that would fit without having to alter the pipe positions, which would require the chipboard flooring to be taken up!
I was hoping to go for a more modern looking radiator, but I may have to accept a basic looking style due to the size.
Thanks.
Thanks.
