Hi
We bought a new Neff dishwasher to go in our new build house and it has never worked! When you start a cycle it begins to beep after a few minutes and a tap symbol comes up which I'm told indicates low water pressure or bad water supply. If you open the door and shut it again it begins to work again and then beeps after a few more minutes. This beeping happens a few times at the beginning and end of a cycle but it seems to work in between.
We've had a couple of plumbers round to look at it and they can't seem to get anywhere. The last one suggested that we would need to install a pump on our whole water system in order to improve the water pressure. He warned us this would be costly and disruptive so are keen to avoid this is possible!
Any suggestions would be greatly appreciated!
Robyn
Robyn
