We have been having problems with our Grant Votrex Pro Internal Combi boiler since we moved into our recently renovated rental property in Nov 2016. Here is it's story - I'm hoping someone might have come across something similar, or that someone with better knowledge of boilers than me might be able to shed some light on what could be going wrong.
We initially noticed that we could not run the shower at full pressure and maintain a warm temperature - it would slowly run cold after a few minutes. We didn't think much about it, and just used it at the lower pressure.
In early 2017 (by March) we noticed that the boiler was switching itself off, and we had to press the overheat over-ride button to switch it back on again. A plumber came to see what was happening, and said that we needed a Grant engineer. The Grant engineer replaced the circuit board (May 2017).
At this point we had solved the pressure problem with the shower, and it was running at full pressure and heat with no problems. The overheating problem though, continued. The Grant engineer came back again at the end of May, but we couldn't replicate the problem.
During the summer we weren't using the heating, and we had no issues with the boiler during this time. In September, we starting to use the heating again and the overheat issue returned. Only this time we couldn't always press the over-ride button - we'd have to wait several hours before we could press the button and see the boiler come back to life (but sometimes it would work right away). The Grant engineer visited again, and still could not replicate the problem, but asked us to log every time it happened (as follows).
The boiler would only go off after the shower had been in use. It didn't seem to matter the length of the shower, the pressure, the switching the shower between the two shower heads, whether the heating was also on at the time, or if someone else ran a tap while the shower was in use. But it never went off while the shower was actually in use. It would usually go off after a hot tap had been run after the shower had been used. Sometimes, however, we could do exactly the same routine and it would not go off at all - but I did noticed a potential pattern with the outdoor temperature. The boiler was generally overheating when running a hot tap after the shower had been used when it was less than about 10'c outside. When it was milder, there weren't any issues. This was true for 14 out of 17 occurrences (the other 3 occurrences were consecutive days).
Oct: 11 times off after shower during colder weather (12th to 19th and 24th - 26th Oct not off at all - above 10'c outside)
Nov: 3 times off after shower during colder weather (2nd - 5th Nov not off for 3 showers despite lower outdoor temperatures - not consistent)
Dec - not off at all (despite colder temperatures, potential start of hot water problems. Oil tank refilled at end of Nov)
However, recently we have gradually seen a return of the original issue; not being able to have a warm shower at normal pressure. This time it seems worse - it has to be a very weak pressured shower to get any heat at all. There is nothing on the boiler that indicates an error. At normal pressure, the hot water gradually fades to a luke warm temperature after about 6 minutes of continuous running. Once the tap/shower is turned off, hot water returns again a short time after - probably after about 5-10 mins but this is difficult to test without running the tap!
Other observations:
- when running one hot/cold tap and then turning on another hot/cold tap (such as running a bath or flushing the loo while running the bath/shower) there is a significant drop in pressure. Although this is understandable, I don't remember this being quite so significant when we first moved in, especially with the hot tap affecting the cold and visa versa.
- with the current issues, the hot water we do get seems hotter than usual.
- the boiler does not have a gap around it for air circulation - it is surrounded by walls on 3 sides. I expect this could well be causing an issue, but it doesn't explain the intermittent nature of the problems.
- There is no 'timed' option installed on the boiler. The heating is controlled by a wall mounted thermostat.
- The pressure is fine, the dial reads 1.5.
- The boiler appears switch between water & heating as it should, and continues running after the hot water has been used (to get the water back to temperature).
Any thoughts would be welcome - even our Grant engineer has now drawn a blank! Thanks
Other observations:
