I am replacing a halogen floodlight (with inbuilt PIR) with an LED unit (primarily to avoid having to change bulbs which is a pain).
The supply has
Brown - Live
Grey (with blue sleeve) - Neutral
Black - Switched live?
Yellow/Green - Earth
The lamp has Live, Neutral and Earth.
The PIR has 4 terminals (L, L1, Earth and N) and says to connect
Supply live to L
Lamp live to L1
Both earths to earth
Both neutrals to neutral
I did this and had the 'black' in a chock block...but the light doesn't work. I know the rest of the cabling is fine since the halogen was working ok and I know the LED floodlight is okay as I tested it before installation.
Can someone help?
The supply has
Brown - Live
Supply live to L
Lamp live to L1
Can someone help?
