So why does 543.7.2.1(ii)a mention a ring? A bit of an inconsistency.
Not at all - 543.7.2.1(ii)(a) says you can have a ring, 543.7.1.3 says how big it has to be.
No inconsistency.
I could wire a circuit with singles in conduit which complies with either your version of the requirements for a high integrity cpc or the version written in the regulations, but if I used the wrong sized conductors it would not comply with other regs.
No inconsistency.
Well, that is the difference between you and me. If I am uncertain about a regulation and how it should be interpreted I will look them up in the guidance documentation issued by a body who should know how to interpret them, in this case it is the same body who issues the IEE regs.
Firstly I'm not uncertain - the wording in the regulations is entirely clear.
Secondly why do you choose to believe a non-BS publicaton which explicitly says that it doesn't ensure compliance with BS 7671 and clearly contradicts what the published standard says and creates all manner of inconsitencies which ought to signal to you that its interpretation is at least suspect?
Thirdly, are you
really confused, or have you simply taken what the guidance says and tried to make it fit with what the regulations say by inventing requirements not mentioned in the regulations and ignoring the inconsistencies?
From each point there are two conductor paths. If you disconnect one you still have a path back to the MET via the other so in a healthy circuit there must be two paths. In a healthy state, the protective conductors combine to make up a ring protective conductor.
No matter how many times you say that from each point there are two conductor paths the wording of the regulations will not change.
And the wording is "two individual protective conductors, each complying with..", not "two individual conductor paths from each point".
The regs require two individual protective conductors. The guidance advises that a ring protective conductor provides a duplication of the protective conductor which meets the requirements.
The guidance is not given in BS publications which are able to define or amend formal national standards. And the guidance is in publications which say that they don't ensure compliance with BS 7671.
I note though that even if we accept that the presence of two paths is what is meant by the regulations you have still not managed to explain how the diagram with the ring cpc shows both a single protective conductor path
and two individual conductor paths, without any inconsistencies.
I'm completely lost where you are coming from with this one. Are you meaning wiring a ring with a multicore sheathed cable? If so then it isn't required.
The regulation doesn't say it's
required, that's not relevant to this discussion, and it does you no favours to try and evade answering questions with utterly irrelevant observations like that.
Since you're lost I'll recap the flow of this little bit.
We were looking at the situation covered by the 2nd paragraph of 543.7.1.3 (iii) where the two individual protective conductors required by the first paragraph were either cores in a multicore cable or where one was a core and the other was a sheath or braid etc.
You said "
The protective conductor core is one conductor path and the sheath is another."
So I asked you if
each individual conductor, i.e. the core and the sheath, provided one path.
And you said "
No, two separate".
So if
each individual conductor provides two separate paths, and we have two conductors (the core and the sheath) we must have four separate paths, because 2 x 2 = 4.
Of course it matters what it covers. That is the whole piont of the regulation. If you look at page 120 of guidance note 8 there is an example of it being used in a radial.
OK fine - there is an example of it being used in a radial. It doesn't matter where it's used.
You say that the first paragraph of 543.7.1.3 (iii) doesn't mean two individual cpcs when it uses the term "two individual protective conductors", but then immediately after that the 2nd paragraph starts talking about the situation when these two individual protective conductors clearly are two individual cpcs.
As we know full well that 2-core SWA can be used with the cores as phase and neutral and the armour as the cpc there's no way you can say that the cores and the armour are not separate conductors in the same cable. So the 2nd paragraph is talking about a situation where two separate conductors in the same cable are used to meet the requirement of "two individual protective conductors".
Could you please read through both paragraphs again, and without trying to fall back on things like "well what it actually means is two paths" or "well that's not what the guidance says so it must be wrong" will you please explain why the most logical and consistent meaning of "two individual protective conductors" is not the one which is based on what the words actually say?
