High temperature resistant glue
3 Sep 2006
West Mids
Any anyone recommend a suitable glue for sticking something on an oven?
Preferably something available in a small quantity.
A couple of years ago my BiL was over from Oz and asked the plumbers about (I think) a flexible flue sealant for his coal range. Somebody recommended some kind of silicone that withstands high temps. Ask over there.
Will that gasket/sealant type stuff work as glue?
I need to stick a thin magnet and associated bit of steel to keep the door closed
Woody - to be honest no idea. And I too was surprised as I was not expecting silicone to "fix metal brackets, hinges and glass in oven doors". However, perhaps it does do this mainly though the large contact area, whereas you will have a relatively small contact area with the magnet to glass and metal to metal. But as both are non-porus then perhaps silicone will form a good adhesion? Anyone tried this?
IGNORE THE FOLLOWING >>> I GUESS YOU WANT THE METAL AND MAGNET INSIDE THE DOOR {I would have used Araldite, it does have a -20 to +80oC temp range, and on my oven the glass does get hot, but I am sure (actually guessing) that it is around 80oC or less than 80oC. }
sfk
I used Araldite to glue an oven door magnet. After a while it failed.
You can get double sided foam tape for ovens, used some re-fit a door glass.
everbuild do a silicone that is good up to 300 celcius
It may vary depending on the type of magnet (ferrous/rare earth etc) but magnets can lose their magnetism at high temperatures - I know for iron magnets it's at about 1300C so not really an issue here but the cheap ones made from powdered composite materials might have a lower curie point.
