- Joined
- 11 Jan 2004
- Messages
- 42,752
- Reaction score
- 2,636
- Country
Rob:
Did it have a pipe clamp on it or a properly sweated joint onto the lead?
... or maybe they did test, and found that it was OK at the time - a lot can happen/change in 15 years!Definately not a DIY lash up, but I suppose it could have been done by a previous sparks. The CU looked about 15 or so years old, so maybe at the same time as this, but without actually testing that the earth was any good.!
Interesting. I would have thought that if it were a metal-sheathed cable, even a DNO would feel obliged to earth that sheath. From what you say, I guess not!From the way Mr DNO was talking, the network has never been earthed, rather than a fault on it.
I guess that's a possibility. How old is the property, and what sort of vintage is the cutout?It might be an earth supplied from the water or gas before they were changed for plastic pipes job.
I did tell you that eons ago.Interesting. I would have thought that if it were a metal-sheathed cable, even a DNO would feel obliged to earth that sheath. From what you say, I guess not!
You must have a much better memory than I do! Mind you, an eon is an awfully long time to expect anyone to remember something (and even I am not quite that old)I did tell you that eons ago.Interesting. I would have thought that if it were a metal-sheathed cable, even a DNO would feel obliged to earth that sheath. From what you say, I guess not!
Kind Regards, John
