We have just had a uPVC front and back door fitted but are getting draughts. Mostly through the hinges but also along the bottom of the doors. I have checked the frame and found that the hinge side is about 4-5mm bowed. The company who installed the doors is telling me that 3mm is the allowed tolerance. I am convinced this is the reason for the draught.
When the fitter came back to check he said there should be draughtproof foam tape in the hinge so he put some in. I am not convinced this is correct, the foam tape is sticky on both sides so when the door is closed bits of the foam have stuck to the frame. He guarantees me that this is a manufacturer standard and that the sticky wears off. Well I'm not convinced, does anyone know if that is correct?
Thanks for your thoughts!
He is also suggesting that a thicker gasket be put in the frames which should resolve the draught problem. Again, I'm not overly convinced but am prepared to see if it does.
