Hi All,
Great forum
I can see myself living here for the next year or so draining you all of advice! I do have some skills so will hopefully be able to contribute too!
i'm embarking on a single story extension and loft conversion project and hope to do a fair bit of the work myself. I have successfully renovated my last house but nothing of this scale. I am awaiting planning permission but am expecting a positive outcome, so I'm trying to plan as much as possible so I can be quick out of the blocks when I get the green light. Enough of the waffle and on with a specific question....
I am doing a hip to gable loft conversion so I need to build up the gable end wall. I am going to be getting tradesmen in to perform most of the structural work and certainly the brick work but I want the process clear in my mind before getting quotes for specific parts of the job. What would be the standard/preferred sequence of work? As far as I see it can be broken down in to a number of tasks:
1) Strengthening the floor.
2) Building gable end wall.
3) Changing the roof shape and adding dormer to rear.
4) Finishing off inside.
I appreciate there's a lot more to it than that but am unclear as to how long I'm without a roof and what needs to be done to enable the gable wall to be built.
Is the list in the right order? Should the floor be done first...while the roof is off...does not matter?
My real confusion is surrounding the gable end wall. Can someone describe what needs to be done to get this built? i.e. strip back tiles to expose rafters then temporarily support existing roof....that's the part I don't get!
Thanks for reading.
7d
Great forum
Thanks for reading.
7d
