- Joined
- 16 Dec 2016
- Messages
- 7
- Reaction score
- 0
- Country
I'm having a nightmare trying to get the Hive unit I've got hold of working with the Baxi DuoTec 33 Combi Boiler I have at work.
The Hive I have got has both the heating and water control buttons (so I believe it's the 2 channel one), but I believe despite this Hive unit being designed for non-combi boilers, it does work with them. I say this because I've had a new boiler fitted at home (a Potterton Titanium 33 Combi) and that has the same 2 channel Hive fitted to it and works fine.
Given that the Baxi and Potterton boilers are both pretty much the same, I've tried wiring up the Hive to the Baxi in the same way it successfully work with the Potterton - no joy.
The boiler powers on (so Live/Neutral/Earth are all hooked up correctly), but can I hell get it to switch on the heating. The hot water still works when a tap is turned on (the boiler fires up as it should), but pushing the button on the Hive receiver doesn't make anything happen.
I've put some images of how I've currently got the wiring below so you can check its correct;
![hive-wiring.jpg hive-wiring.jpg](https://cdn.diynot.com/data/attachments/110/110438-607dad73e6644129c36dae6d458aeacb.jpg)
Just to give a bit more information;
There wasn't already a wired room stat in place - it was a wireless one which basically communicates with the boiler using a built-in wireless module. I've tried disconnecting that from the boiler PCB (just unplugs) since connecting up the Hive, but that still makes no difference.
When I first started looking at this, there was a link cable between points 1 to 2 (in the boiler terminal), so that's been removed as it said it needed to be.
I guess what I'm wondering is whether there's some form of link cable I need to use in the Hive wiring to perhaps connect a couple of points together, but if so, I'm unsure what and don't want to just start putting random cables in for fear of blowing stuff up!
Is anyone able to offer any help with this headache?
Thanks guys!
Steven
![boiler-wiring.jpg boiler-wiring.jpg](https://cdn.diynot.com/data/attachments/110/110437-e97dadf4d3d2e9e24cf824e9231463b2.jpg)
Thanks guys!
Steven
