Ive got a small towel rad to fit on to a hollow plasterboard wall which has been tiled.
the thickness of the wall including tile/adhesive and plasterboard must be around 18-20mm.
I wanted to use hollow wall anchors as these seem like the strongest type and are reusable. however the small teeth on the back of the collar of the wall anchor obviously wont dig into the hard tile face like they normally would on plasterboard so the fixing wont have anything to grip against when tightening it up.
have any of you guys used hollow wall anchors in this kind of situation and how did you manage to fit them?
i was thinking i could potentially counter bore the tile just a bit bigger the than the collar diameter so the fitting sits inside the tile but mounts against the face of the plasterboard.
any other ideas or fixing suggestions that could be used?
