Hollow Wall Fixing: At A Loss...
7 Jan 2014
West Glamorgan
Hi All
Been using hollow wall fixings in my hollow wall house for 26 years but am stumped at the mo...
I have a tile on PB wall, so about 18-20mm thick. I need to fix the 2 bits of the shower riser rail to the wall (the bits that hold the pole). Not much load, but I need a fixing 80mm ish long. Why? These flippin mounts require the screw to more or less go all the way through it, meaning at least 38mm of the fixing is wasted in the mounting.
So a toggle will need to be really long to clear the PB, but an 80mm toggle will need a 15mm hole, which is overkill. Intersets will be too short, and may not pull up on 20mm of wall anyway.
Would the wallplugs with 'wings' do the job?
Any ideas very welcome? Ta.
My first thought... Can't get M3 screws 80mm long. (Well not readily...)
M3? Why would they be machine screws rather than "wood" screws. M3 is tiny. I am guessing that they would be PH or PZ1 heads?
Orbital fastenings are great for hard(ish) to obtain screws. They will sell screws in single quantities-subject to a min order of £25 ex vat for free delivery (next day if in the M25). I used them at lot recently when working at a customer's house when I discovered that the builders had lost the screws for the bathroom fitting and used any old screw that they had to hand.
I suspect that the screws that you need are 3.5mm (+) tapered screws rather than 3m machine thread screws.
As much as I like them, I don't think interset will work on tiles because of the "teeth" on them. When putting up risers/etc, I use the nylon plugs that the screw pull sin form the back and spreads. I also dab a bit of silicone in to the fitting before using the screw so that is is shower proof.
I assumed he means these:
ae235
/QUOTE]
He does! I use those a lot, but the screw (is machine screw the correct term?) is too short. The spring toggles I have are M3 screws, but again, too short. So I was trying to get longer screws that I could use on either fixing. I will prob have a go at the nylon ones that use a wood screw and 'crush up' behind the PB.
Doh! My reply is in the quote!
Missed this Opps, yes, that's where next. And the silicone round the fitting is a good shout too.
Sorry, my confusion was compounded by the mention of a M3 screw, I have only seen a min of 4mm machine screws in intersets.
BTW, the Rawlplug intersets can deal with up to 36mm in plasterboard thickness.
https://www.rawlplug.co.uk/product/sm-interset/
The smallest diameter ones that seem to fit your requirements are these
https://www.orbitalfasteners.co.uk/products/m5x65-interset-cavity-fixing-rawl-pno-r-sm-05065
They use a M5 screw and require a 9mm clearance hole. Unfortunately the screw is only 65mm long but that I am guessing that they will be long enough for you (once the interset has been pulled "closed").
