Honetwell BD91 to Nest
26 Oct 2016
Need some help please trying to replace my Honeywell with the new Nest on my Baxi combi boiler.
The wiring on the Honeywell is
N - 240v neutral
L - 240v positive
A - 240v
B - 25v
C - not connected
The wiring on the Nest I know is
N - 240v negative
L - 240v positive
1, 2, 3, I have no idea how to wire these.
Look thanks for the help. I am skilled electronics engineer not a gas safe heating engineer. I know enough not to wire 240v where it isn't supposed to go. I have looked at all the information i can find and at this stage am a little confused (don't take much I hear you say)
So you are basically saying wire 240v to 2 and 25v to 3 on the hive?
many thanks for any help, sat here with it hanging on the wires on the wall!
Another note, the Hive wiring instructions say to loop connect terminal 1 and 2 ?
They do not, because that would just connect the common and the rarely used normally closed switch contacts together permanently.
L&N / L&N are the mains supply to the device
A&B / 2&3 are the normally open contacts which are used to activate the boiler.
  • Thanks
Reactions: CBW
Where are you getting 25v mixed with 240v from?
