Honeywell ABV DU144 and DU145
15 May 2022
Cork
Ireland
If a bypass flowrate of 420LPH is required at a pump head of 6M then the DU144 (top, below) will achieve this at a index setting of 0.5 but
this is not possible with the DU145 (bottom, below) as it will only give a minimum flowrate of 800LPH at a pump head of 6M at its max index setting of 0.6.
Has anyone used the DU145 where bypass is required at high pump heads?
