On Evo, do you know exactly what the "hot water differential" is for?
No idea! Didn't even know that Evo could control DHW.
Normal HW cylinder thermostats have a differential of about 10C, so if you set it to 60C the stat will open at that temperature but not close until it has dropped to 50C. All I can assume is that the EVO has a facility to vary this differential, if the application requires closer control of the HW temperature.
jpadeutch said:
So I guess that overall the pump will not be active for any more time than it would be on a unit without this feature.
The boiler should be running for much less time. As for the pump, this may run after the boiler has stopped - it's called pump overrun. The purpose is to cool the boiler. So there's a possibility that the pump
might run for longer; but I won't lay any money on it.
What happens if the calculated time for it to be on in the next 10 minutes is less than the minimum on time?
The boiler will light for the minimum of one minute, even if the TPI says it only needs 30 seconds.
However, the 10 minute cycle time is not fixed; it's just a starting point! It can be made longer under the control of the TPI algorithm. This is not made clear in the standard literature; I found it online in a Honeywell Powerpoint presentation introducing the CM900 series.
If you have a very well insulated house, so the temperature drops very slowly, the cycle time could be half an hour or more, with the boiler lighting for only a few minutes.
You will find that, once the house is up to temperature, the radiators will feel relatively cool as they do not have to produce full output to maintain the room temperature, just enough to top it up when the temperature has dropped half a degree.
It's just like driving a car: you need full power to accelerate to 70mph; but you can cruise at that speed with a very light throttle.
