Honeywell frost stat kit
There is a wiring diagram showing 2 frost stats which I would like to revisit as I am having problems with. I am not a commercial site. I am able to get the transcript of the topic if I use search by author, but not the pictures.
do you have one wall mounted and one pipe mounted 'stats?
what problem are you having?
I have an S Plan layout with a frost stat in the garage with the pipe stat on the return to the boiler(which is also in the garage) connected to CH motorised valve and a frost stat in the loft with the pipe stat on the return from the HW tank just before bypass and connected to the HW motorised valve. I have all the wiring on a Honeywell Junction box.
I want to reference diagram in the missing topic to check I have connected up correctly as the boiler seems to be firing up quite frequently. The frost stats are set at 5 degrees.
is your cylinder in the loft?
it's not usual to have a frost stat in loft unless the actual boiler is there.
Thanks for all your replies.
But what I really want is either someone to draw me a diagram with both
frost stats connected to an S plan or for the moderator to reinstate my
previous topic.
