I realise that this is a common fault but I would appreciate some advice before trying to rectify it. Last night I switched the CH on for the first time but none of the radiators warmed up. I manually moved the lever on the valve and everything warmed nicely. Unfortunately having returned the lever to auto, the valve will not close when either the timer is set to HW only or the thermostat is switched off. I'm not sure if the problem is likely to be a stiff spindle, a failed motor or another failure within the actuator. I tried to remove the unit last night but realised that one of the two fixing screws was actually unscrewing the brass lug that holds the brass plate in position and also receives the actuator fixing screw. My questions are:
1) If I continue to unscrew the brass lug until fully removed would you expect the unit to start leaking? At the moment I cant free the fixing screw that holds the actuator in place from the brass lug...
2) What is the most likely cause of the unit no longer working correctly?
Thanks in advance........
