We had a honeywell VC4613 valve with a leaking stem which has wrecked the electrics in the actuator. I've just bought an Iflo valve on ebay also with 6 wires. Anyone know if the new one will be OK to fit?
Yes it will be fine. Wires are the same colours but the body will have different nuts than the honeywell one so use the complete contents of the Iflo box. Mind and get it going in the right direction. Honeywell goes from A to B and iflo follow the arrow.
