I had a bedroom converted into a bathroom with sink and shower. Both have traps, connected to a 40mm waste pipe that runs under the floor practically horizontal with several 90 degree bends for 2 meters, then on a 1:30 incline and into a soil stack. I have two problems that happen only occasionally:
1) the shower drains very slowly
2) using the sink causes water (or at least soap bubbles) to come up from the shower drain
Before jumping to the conclusion that there's a clog, I should add that it can also happen soon after plunging the drain. So I'm not sure that there's a clog like a hair ball, but I'm wondering if it's possible that bubbles (from soap or just air) get trapped somewhere in the horizontal section and restrict the flow on one random use of the facilities and pop when the water flow stops and don't re-form the next time? If anyone has heard of this or have another idea, could you advise me how to fix it please? There's no easy way to get to those pipes now as they are under a tiled floor. I've tried plunging, pouring in unblocking liquids, nothing helps, it seems random. Many thanks!!
