the only way(because of the pipe work) i can run a pump to the shower is using a single impeller on the hot and run the cold off the mains to a thermostatic shower?any one see any problems with that?
wheres the best place to put the prv? is there differnt prv for diffenrt pressures?or can you change the setting?the pump is 1.5 bar and the mains is around 2 bar depending on time of day?
