I have a fully pumped central heating system - Potterton Sprima boiler 80L (about 4 years old), Grundfos Selectric pump, Honeywell Sundial Y Plan 3 position diverter valve, Potterton programmer.
I have had a number of problems with the system. The main problem is that when HW & CH are both on the rads do not get warm, even after several hours. When I switch to CH only the rads get a little warm at the top but it seems to take a long time. The return pipe back to the boiler appears to be cold still after several hours. Is this a problem with sludge in the CH system or a faulty 3P valve? There are two towel rails fed before the 3P valve which I have turned off to try and increase the flow in the CH, but the boiler then locks out.
There is still a lot of air in the system even after 4 weeks of refilling it after I moved the pump. After moving the pump the system worked very well for a week or so and then went back to its same problems.
