Hi, I have a 22mm thermostatic mixing valve (in a rest home). it is sited about 5 metres from the bath. Recently the hot (mixed) flow has diminished significantly. I have cleaned the mesh filters and the check valves on the inlets. The hot water feed seems ok at the kitchen tap on the same floor which is not controlled by a valve.
having reassembled the valve the hot flow in the bath now seems to pulse every 10 secs or so as if the hot water is struggling to get through the valve.
Do you think the valve needs replacing (its been working for about 8 years). Also could I put a pump before the valve on the hot feed to boost hot water pressure or is this a no no.
the hot water tanks are on the ground floor as is this bathroom and valve and they are fed by cold water tanks on the fourth floor so there should be plenty of head, however the pipe from the hot tank does run up then along the ground floor ceiling then back down to the valve cupboard.
Hope this makes sense. Thanks in advance for any advice.
