installed a bath on a like for like basis, using existing 22mm copper (on an older style house).Hot water is fed from a combi in cupboard next to bathroom. hot flow is poor...would changing a section of 22mm to 15mm upto tap make for better pressure???
Why would making a pipe SMALLER improve the flow???? Bigger pipes = less resistance = more flow.
Or do you mean that the water flow is OK but not hot enough (= boiler not man enough).
Or water takes a long time to get hot (MIGHT be due to large static volume in 22 mm pipes but unlikely to be significant).
Or do you mean something else entirely?
