I recently upgraded my central heating system.
The old system was a very basic time switch which when activated supplied power to the pump and the boiler. When the timer ended power was cut. When heating was on hot water was on and vice versa.
I purchased a Danfoss Y plan kit and a Grundfoss pump (the old pump was on it's way out)
In terms of pipework I basically just replace the T peice which went between water and heating with the Y valve, and replaced the pump.
I wired it all up and it all functions perfectly everything switched on and off as required.
What I did notice was that when the timer switched everything off, the vent pipe got hot very quickly and when I checked the header tank in the loft the water was warm.
I asked about that on here and was advised to add a pipe stat to the flow pipe from the boiler to overrun the pump after everything is switched off. I did this and that cured the hot vent pipe.
All was fine and it's run like that for a week but now I have found another problem.
If the hot water comes on, on it's own without heating the Vent pipe becomes hot again even though the pump is pumping and it drips into the header tank. The pipe coming out of the bottom of the cylinder goes to a T peice which is a verticle pipe, I think this possibly joins to the vent higher up?? Anyway that pipe gets hot as well all the way up.
Is there any usual cause for this - should I worry? (I don't think it's right)
The only obvious thing I can see is that the output from the bottom of the cylinder comes out as a large pipe (seems a couple of mm bigger than 22mm - migth be wrong) but then instantly goes down to a 15mm pipe with a gate valve in it, this then goes to the verticle pipe I mentioned before which again is 15mm.
Is the 15mm pipe restricting the flow?
Another problem I have had since this happened is quite a bit of air in the system, one rad keeps getting a bit of air in it (the bathroom rad) and you can hear it going round the system. It takes about 20 seconds of nice silent running then you get 10 seconds of air type noise going through the pump. I can open the bleed bit on the pump and it expells some air but seems to take ages to bleed.
Is this related? Maybe the water was boiling?
