Hot water, no heating. Help please!
31 Oct 2015
Hey
So I need your expert advice.
I have an Ideal FF250, in an pumped system, with a header tank (though no overflow vent) and a HW cylinder. It's a heat-only sort of boiler. It has two honeywell two port valves, and has been connected to a tado.
On switching the heating back on, I've found it doesn't work, despite getting hot water. I've checked out the valve, and made sure that it's not stuck - but found that it doesn't receive a current when heating is switched on. I've ruled out the controller as the problem too by putting the CH to live (as instructed by the Tado guys).
That leaves me with the boiler. It will happily heat water, but doesn't make a sound on heating-only. Pump doesn't turn on, and there's no voltage to the CH valve. There was some air trapped in the system last year, following a drain down and refill, but the header is full.
Could this be the problem, or is there something else I'm missing that may be the cause?
Your help would be really appreciated - thanks.
J
hey 75pete
Thanks for the reply.
It's a Tado internet connected solution (so no click, but indication online that it's set to on at current temperature). I've been assured that the thermostat is sound, but I think shorting of CH circuit (connecting it to live) bypasses the thermostat anyway?
You need to check that you have voltage going to the brown wire on your heating valve. If not then you are looking at a problem with the controller or wiring.
.......and if you have and the motor fails to move, then it's your synchron motor.
Got a customer with one of those Tado things that hes installed himself on a glow worm last week.
Boiler happens to need a new pump and water pressure sensor but he wants me to check that chuffing Tado's wired right.
Glow worm boiler and the powers been off for a week on it. Just waiting for the PCB to blow the minute I power it back up; hes been warned.......
