hot water problem
8 Jun 2008
Middlesex
i live in a ground floor massionette, i have a fairly new ideal icos boiler and a drayton digistat 2. the problem i have is that the only way i seem to be able to get hot water is if i turn the central heating on by the digistat.i don't have any other controls by the boiler to control the hw, just the digistat. can any1 help me as to why i don't seem to be able to get hot water without the heating on???
im assuming that this is because the boiler will only fire up when the heating comes on...
do you have 1*3-port valve or 2*2-ports
do you need both ch and hw turned on at prog to get hw or does it get hot when the ch is on and hw off.
i dont know if its a 3 port or 2 port valve, plumbing is not my strong point sorry, how do i tell?? the programmer is a room thermostat only. it doesnt have any controls what so ever regarding water.
I assume you do have a hw tank in an airing cupboard.?
no im pretty sure it isnt.according to website its just a high efficency boiler and not a combi.
yea i have a hot water tank in the airing cupboard. and a water tank on an adjoining cupboard that sits around head height.
Best not put it in a skip - some scavenging oik might remove it and try to use it.
There's a universal tool for fixing any problem with any Ideal combi boiler:
