R
roberta1000
I had my boiler replaced last summer. Previous system was gravity hot water. The HW tank is very close to the boiler and the piping is the original 28mm apart from a foot or so coupling to the flow and return.
When the HW is heating, the radiators cool quite a bit. Also the boiler modulates down at the same time even though the heating is on. I think it's likely a balance problem with the HW circuit taking most of the flow. Meantime I'm timing the HW to be on when the CH is off but I think that overall that will use more gas (?).
Is it possible to fit a restricting valve in the HW circuit? Can I get something suitable in 28mm or should I fit a section of narrower bore? If I fit a valve would I balance it by trial and error or similarly to the radiators? Thanks.
