It's a combi boiler. When I open the flap at the front it only has a dial for the radiators, which i turned down just incase but had no effect on the water temp.
There will be a thermostat on your cylinder approx 2/3 up. Turn it down a little. The water should not be stored at less than 65 degrees so gently does it.
