I have a Vokera combi boiler, at the moment when I turn on the hot water tap it is taking about a minute before the boiler cracks up and a little longer for the hot water to apppear. The CH is ok, any ideas???
cold feeds from tank in loft derived from the war.Due to bombing, many mains were destroyed , so the cold was fed from the tank so as to be able to still wash and use the toilet.
I counted how long from turning the water on until it the boiler started up (45 seconds), as I said previously, the CH seems to be alright and starts the boiler straight away.
Good chance the boiler has not been serviced (properly) for many moons. If you get the boiler serviced as the makers suggest (not the 15 minute service), there is a good chance the boiler will function as intended.
Where in the country are you. Perhaphs one of the regulars may be able to rescue your boiler.
