that code means f o5 filter blocked or pump not running the filter could be in 2 places depending how old the mc is .first remove kickstrip at front if there is a red circle filter is at back .at the back there is a small white panel with about 3 screws remove and you will see filter a big black sump remove the filter you will need towels and a bowl .if filter at front twist and remove,
