Hotpoint Ultima tumble dryer - no heat!
18 Sep 2005
Nottingham
My Hotpoint ultima tumble dryer model TDC 62 is operating, but there is no heat. Presumebly thr element has failed? is this repairable?
Any help appreciated!
D. Cooper
It's repairable but check the thermostats on top of the heater first.
check with a multimeter set on ohms this reads through the thermostat to confirm there is a current path intact. The reading when you check each thermostat should read low ohms if it reads high or infinity the thermostat is open circuit.
To reset the stat push a sewing needle into the hole at the centre of the stat until you hear a click.
