HI, WONDER IF ANYONE CAN ASSIST ME WITH THIS PROBLEM ? I HAD THE MACHINE ON DRYING CYCLE ( LOW HEAT ) AND IT WAS WORKING FINE FOR AROUND 25 / 30 mins, IT WAS THEN I NOTICED THAT THE WATER WAS CONTINUALLY FILLING THE MACHINE AND THE PUMP WAS CONTINUALLY DRAINING IT !!! THE LIGHTS FLASHING ON THE MACHINE WERE 3 & 4 WHICH I GATHER FROM A FAULT CODE LIST I ACQUIRED OFF THE NET TO BE AN " Ntc FAULT" ?? BUT JUST EXACTLY WHAT IS IT ? LAST NIGHT I HAD PROBLEMS WITH THE MACHINE TRIPPING OUT THE Rcd ON THE CONSUMER UNIT, WHICH AFTER RESETTING 3 / 4 TIMES, BLEW THE 13A FUSE IN THE PLUG. I LEFT IT AFTER THAT AS IT WAS LATE, CAME TO IT THIS MORNING AND IT ALL SEEMED TO WORK FINE UNTIL THIS PROBLEM AROSE ! ANY HELP APPRECIATED. THANKS.
FORGOT TO MENTION, I FITTED A NEW HEATER ASSEMBLY ON THE WASHER SIDE OF THIS MACHINE TWO DAYS AGO WITH A NEW SENSOR INCORPORATED IN IT.
