What did it blow, fuse in plug mcb or rcd and after replacing what is the current state of the machine does it reblow fuses etc or is the machine just lifeless with no lights.
Have a look see if there's a hole in the door seal.
A common problem is water getting onto the door interlock, big bang and it takes out the timer/module with it too.
