- Joined
- 23 Dec 2019
- Messages
- 37
- Reaction score
- 2
- Country
I'm having a rear extension built (architect has drawn plans), and soon want to contact builders for quotes etc. Expecting the build alone to be ~£80k+.
Currently, I've no building details/specifications whatsoever - just drawings of the brickwork (no drawings of how existing parts of the plumbing and drainage will need to be re-routed - which they will; nor drawings for gas piping/electrical cabling).
I want to keep costs down AND TO BE AS HELPFUL TO BUILDERS (probably a main contractor) AS POSSIBLE. I recognise that their time in creating quotes is valuable etc.
My question is:
Do builders / building contractors generally want the flexibility to 'design' and 'specify' the build themselves, and then quote for that [which presumably means each quote you get is for a somewhat different quality of materials and build]
OR
Do they prefer to work to a highly detailed specification, and quote to exactly that?
As I say, I want to ATTRACT some builders to the job, so don't want to approach things in a way that will immediately put many off.
My current idea is to employ a building contractor SOLELY to create a detailed specification (knowing that I won't be using them as the actual contractor), and then to 'give it' to other contractors to quote for.
But I certainly don't want to do this if many building contractors don't want to work to building plans specified by someone else.
Thanks for any advice
My question is:
OR
