One of the occupants in a home of multiple occupations I managed left the cooker for longer then It should be and all his food burned. The house was full of smoke but none of the smoke alarm was set off. The house has a complete fire alarm system consists of the following:
2 photo-electric smoke detectors one in the landing downstairs and one in the landing upstairs.
7 thermal detectors one in each room and one in the kitchen and one just outside the kitchen in the utility room 5 in the bedrooms. However the ones in the bedroom are different in shape from the one in the kitchen and the utility room but all written on them “thermal detector”.
2 ADDRESSABLE CALL POINT red in color one close to the back kitchen door and on in the second floor written on them “break the glass in case of fire”
2 big red bells one in the dining room and one in the second floor.
The hole system is Hochiki make.
When I removed the cover of each sensor I can see 4 wires connected to the base of each sensor, two red , two black and the connection as follows:- , one red connected to “live in” the second red connected to “live out”, one black connected to “common in” the second black connected to “common out”
None of the wires had electricity in it when I touched it with a testing screw driver. Despite the fact that the whole system (fire alarm system) is connected to 32A breaker in the consumer unit via 6mm wire (similar to the cooker wire).
When I looked inside each detector, the thermal ones operation voltage is 18-30V DC and the smoke once is 24V DC. The could this explain why I am not getting a light on my primitive testing screw driver?
How can test the fire alarm system to find out where it is working or not. And finally how those system works
