That has nothing to do with this topic.Can you explain how an aqua deck installation creates a step ?
It avoids the step associated with shower trays
No it doesn't.
I'm declining a discussion on this question because I believe it has nothing to do with this topic. Feel free to carry discussing it without me, but I don't see anyone else leaping to join in with you.So tell me how does an aqua deck installation create a step ?.
Have you measured your arm?Very useful info, thanks. But I still dont see how I will be able to reach the 760mm or so under the tray, as the waste will be in a back corner.
In any case, you'd only ever need to reach it for maintenance, and if you do it right then no maintenance will ever be necessary.
On what do you base this article of faith?
I'll join in, Orcon, its aqua DEC not aqua deck. these are for wet rooms, not shower trays.
You appear to be repeating the words that I wrote.Exactly. If you do it right then no maintainance will ever be necessary.In any case, you'd only ever need to reach it for maintenance, and if you do it right then no maintenance will ever be necessary.
Better to start a new thread than tag onto one several years old.
However, if you have a resin stone tray then I would bed it on a weak mortar mix if the manufacturers instructions state that. It is vital the tray has adequate support over the whole base, otherwise if it fails (cracks) then any guarantee would be void if it hasn't been fitted in accordance with the manufacturers instructions.
