- Joined
- 12 Mar 2016
- Messages
- 222
- Reaction score
- 1
- Country
Hello all
I would be most grateful of some advice.
some strange bubbles have appeared on kitchen wall over a period of 6 months, they appear to have air in and if you press them the paint breaks off it.
Here are some photos of them.
http://s8.postimg.org/qx0vio585/Photo0003.jpg
http://postimg.org/image/pknruix69/
So I removed the paint, it was easy as it just pulled right off, the paint wasnt even stuck to the wall. So here are the results of that.
http://s21.postimg.org/j0pq0hs3r/Photo0008.jpg
http://s21.postimg.org/pfoqx5ytj/Photo0009.jpg
Over the last 6 months I didnt know why this wall would always get water on it while cooking? It turned out the cooker hood fan was not installed properly and was not working, it has now been installed properly and no water appears on the wall anymore.
Now I need to know
How to treat the damp part of the wall, maybe use something like this?
POLYCELL ONE COAT DAMP SEAL
http://www.wickes.co.uk/Polycell-One-Coat-Damp-Seal-500ml/p/227974?CAWELAID=120135120000000389&CAGPSPN=pla&utm_source=google&utm_medium=cpc&utm_term=&utm_campaign=Google Shopping - Building Materials&tmcampid=&tmad=c&tmplaceref=KHIKiwU2&tmcustom=mkwid|sKHIKiwU2_dc|pcrid|43364522812|kword||match||plid|&gclid=CLnQv5OEu8sCFUORGwoduIwL8w
To fix it should I follow this procedure?
a) If its a damp/grease mark (which it looks like it is) clean it first with biological washing powder,
https://www.persil.co.uk/wp-content/uploads/2014/01/Persil-Laundry-Powder-Bio-500x500.jpg
b) followed by sugar soap.
http://www.ebay.co.uk/itm/Everbuild-Sugar-Soap-Liquid-Concentrate-500ml-Cleaner-Grease-Stains-Grime-Cleans-/172125176725?hash=item281375c395:g:FcwAAOSwZ8ZW3T6 U
c) Paint with stain block or use an oil based primer/undercoat, but it's no cheaper, and less effective.
http://www.ebay.co.uk/itm/Stain-Block-Paint-for-Covering-Damp-and-Mould-Patches-on-Walls-and-Celings-250ml-/310795622436?hash=item485cdcd824:g:B1oAAMXQV0BSIKK i
d) Then use ordinary emulsion (wall) paint, and finish with kitchen emulsion paint (or just use the latter). Gloss is for bare wood. Or should I use POLYCELL ONE COAT DAMP SEAL rather than emulsion paint?
z0AAOSw-nZTpCef" target="_blank">http://www.ebay.co.uk/itm/Crown-SILK-Emulsion-7-5-L-Pure-Brilliant-White-Wall-Ceiling-Paint-Wipeable-/161990929494?hash=item25b7696c56:gz0AAOSw-nZTpCef
I have noticed around some of the edges the paint is not sticking to the wall, should I pull those parts off? Most of the edges of the paint are stuck tight to the wall and I really would have to scrape it off, but some edges are loose, should I pull those away until I reach a part where the paint is stuck tight to the wall or should I just leave it?
What would be the best type of paint brush for this? Maybe these?
HsAAOSwpRRWoBS 0" target="_blank">http://www.ebay.co.uk/itm/Harris-T-Class-Delta-Paint-Roller-Kit-Set-6-Sleeve-Trade-Pack-9-/221796552069?hash=item33a41acd85:gHsAAOSwpRRWoBS 0
Out of interest, what type of wall do people think that is? Plastboard or hardboard?
What colour paint does that look like on the wall? Brilliant white maybe?
Does it look like there was an undercoat on the paint I stripped off? How can I tell if there was? I know the paint peeled off very very easy, does that mean it probably did have an undercoat?
Now I need to know
